1 - 2 of 2 Posts
i put a fan clutch on in dec 10,(it was making a vibaritation niose). yesterday , it started again. my repair manual says not to loosen the cooling fan pulley bolts behind the big nut that removes the clutch, that it is under spring tension. are their bearings in behind this pulley?, could this be why my clutch lasted only 1 month?, can i change this pulley or bearing?. (or did i just get a bad fan clutch and need to replace it again)i use my truck daily to make my living, help. 346,000 miles.
thanks for any help
Discussion Starter · #2 ·
it does, 245.00 list at dodge, got it for 187.50. now ready for another 247.000 miles...
1 - 2 of 2 Posts
