1 - 11 of 11 Posts
ok has anyone had theres actually be close as in .1-.4 from actual mine reads low surprisingly not high all my hand cals are with full tanks fuel visible in the neck and i have done the speedometer correction math for oversized tires and mine reads about .1-.4 mpg low just wondering if anyone had something close
mine is usualy .3 high
If I do all steady driving, mine can be quite accurate. As soon as start doing stop/go type stuff, it can get as much as 2 mpg off.
I'm not sure why, but mine reads 4 mpg high all the time. I have adjusted the computer for larger tires too.
Mine is waaaayyy off.. Hand calc i get 15 or so.. Lie-o-meter currently says im getting 24.
Mine reads anywhere from "Dead-on" to 1 mpg low so I always know I'm at least as good as the OH is showing....
I have also found mine to be dead on most of the time when compared to my hand calculations. About the speedometer correction...I've had bigger aftermarket rims and tires for almost 2 years and have never had the dealer adjust my speedometer. However, I have my rim and tire size saved on my PMt so I get my MPH off that but my speedometer is always 2-4 mph higher?
what gives lol
Thanks
I reset mine everytime I refuel along with my tripometer. Its usualy between .5 and 1mpg high.
the less torque management you have with whatever programmer and/or the bigger the injectors, the more the mpg calculator will be off.
Mine is way off, high, last tank hand calc I got 16.84 mpg all town driving and the lie-o-meter 23 mpg, so that means it was off by 6.16 mpg. I have larger tires and wheels and I reprogrammed my stuff with my Jr. and checked against my gps and I am pretty much on the money between the speedo and gps.
Mine reads the other way than most of you guys are posting. It will say 16.2 and I will be getting 18.5.
1 - 11 of 11 Posts
