1 - 14 of 14 Posts
Will f250 16" wheels fit on a '05 Ram 2500? I don't know what year the F250 is.
no. chevy rims will but not ford
And only the newer 17in chevy rims will fit on a 3rd gen to clear the calpers.
Chevy and Dodge both use a 8-6.5in stud spacing
Ford ever since the Superduty in 99 has gone metric and used a 8-170mm stud spacing.
Has anyone tried putting 16.5"s on a Dodge?
17 inch wheels and larger ONLY unless you are very confident in your grinding ability
i had 16.5 on my 2005 more grinding than the stripclub but with a little grinding and 1.5'' wheel spacers yes sir it will work i had weld 16.5x12 on it they looked like 14s very cool!
will 1999 ford f250 wheels fit my 2000 dodge ram
no, super doody bolt pattern is metric and unique.
old f250 (pre-doody) wheels are the proper bolt pattern, 8x6.5
What about 20" wheels on newer ford & dodges? Calibers shouldnt be in the way...
Bolt pattern is not the same. It will only interchange with GM, and 97 and OLDER FORDS. Still needs 17" or larger
1 - 14 of 14 Posts
