which clutch did you get? ANY of the aftermarket clutches will be noisier. depends on which one you have as to how much noise to expect. i have the Valair DD sprung hub, and it's much quieter than the unsprung models. you referenced 1300 rpm, but neglected to specify which gear it does that in. all of them? that's not normal if so. but 1300 in most gears is going to be lugging the engine and that will cause the noise you describe. keep it @ or above 1500rpm and she'll be happy. it might quiet down a bit over time, but not much from my experience. if you got the sprung hub, the small amount of rollover noise is about as good as you going to find. you should have heard my last unsprung.....LOUD! had to turn the truck off to talk to someone standing right at my door, or going through a drive through. not anymore.Okay- This is my first high performance clutch...and HOLY COW is this thing noisy:shock:. I just hit 34K miles on my 09 truck and installed a Valair Clutch. Is it "normal" for a clutch to be so noisy? If I am around 1300rpms and get on the throttle, it sounds as if gravel is spinning around in the tranny. Also, when the clutch is let out in neutral, very loud.
Any input would be appreciated...please tell me this thing is going to quiet down...
Thanks!
what clutch did you get.Okay- This is my first high performance clutch...and HOLY COW is this thing noisy:shock:. I just hit 34K miles on my 09 truck and installed a Valair Clutch. Is it "normal" for a clutch to be so noisy? If I am around 1300rpms and get on the throttle, it sounds as if gravel is spinning around in the tranny. Also, when the clutch is let out in neutral, very loud.
Thanks!
Yup...I get the same looks. Sounds like a rattle-trap...but it does hold like a MOFO!Mines real loud with the pedal pushed in. Sounds like its chewing up the throwout bearing, lol. Iv gotten used to it, but i still get some cockeyed looks around town, like geeze, this guys truck has problems, lol
I wish I had a tape recorder that explains why the clutch is so loud. No BS I explain it to somebody at least once a week and hell sometimes it's the same people over and over. But like y'all said it hold!! It's either engaged or not, no in between and no riding the clutch or creaping up at a redlight. It makes the truck hope like a sum....lolMines real loud with the pedal pushed in. Sounds like its chewing up the throwout bearing, lol. Iv gotten used to it, but i still get some cockeyed looks around town, like geeze, this guys truck has problems, lol
All performance clutches are loud. My single ceramic button clutch at idle is ridiculously loud. It sounds like an extremely worn out Throw out bearing and a possible rod knock. My next clutch is the triple disk set up but I'm goin with a fluidampr to audit down the vibrabtion. Those help a ton and only $400ish not bad.
