1 - 12 of 12 Posts
tranny is being built so no worries there. also the plate will be cut and 4k springs will go in when the transmission is done.
should i get:
1.Cold Air Intake &
Intake Manifold
2. Injectors &
Cold Air Intake
3. Intake Manifold &
Exhaust Manifold
4. Something else I'm forgetting about...
how about CAI and some injectors...#2
AlGores worst nightmare
I'd look into a turbo. You're going to be getting hot, if you aren't already. Then you'll be OK with bigger injectors too, later on.
SC Chapter President
Try a 4" exhaust and some injectors. Go with the DDP's. Maybe a stage 2?
4 inch is better....5in is best... call richard at coaltrain diesel. i just installed his kit and it screams and the price is RIGHT!
I to am fixing to order the 5" from Coaltrain. Very good pricing.
Id get the exhaust and intake.
*edit* nevermind I see you already have the exhaust....I would get sticks and intake then...*
intake and injectors.....
Discussion Starter #9
dang! 25 hp gain is pretty nice! yea i have straight MBRP 4" right now. i plan on 6" flat tops later. injectors and intake? or what does everyone recommend. what about 330s? bad spray pattern? whats the best injector set for around $500?
i hit about 1000-1100 degrees max when boosting 30 psi. plate is going to a number 100.
I aleays thought that a 6" exhaust would make you lose power. But then again I guess if I had the mods dual k20s does I might need the 6". Hopefully one day I can get the old beast there!!:)
Tech Specialist
I was being sarcastic if you didn't notice.
The gain of 5" over 4" is neglegted with the stock turbo and its really small turbine wheel and exhaust outlet. 5" is 1.56 times the size of 4 and 6" is 1.44 times the size of 4". Above 500hp there might be a measurable gain going to 5" but it won't be noticable, and as a percentage it will be small. I wouldn't use 6" unless I had a turbo with a 6" outlet
Discussion Starter #12
ooops. sorry man. i can be a little special sometimes! i just like the look of 5 inch! maybe a 5" tips should happen till the stacks. but thank you yet again for the information!
1 - 12 of 12 Posts
