I was wondering those with extended shackles and or Deaver / Atlas spring packs, does any one know how much the shackles swing back under full compression or when articulated out. Currently planning on some boxes for the side of the truck and would like to avoid contact the spring movement, while maximizing the storage space. With stock shackles it seems there should be no issues, with extended shackles the clearances can get close depending on how far they swing back by the red arrow.
Any input would be appreciated or if anyone has any photos of how the springs / shackles sit at ride height and articulated it would be helpful.
This is where the factory setup is, but will be getting new springs once things are done.
