05 Dodge 3500 with the 5.9 cummins. Osilating vibrations at different speeds is the problem, 38 to 40 mph, 58 to 64 mph, 72 to 78 mph. more pernounced when climbing hills or pulling a load. One shop said you need to replace your 4X4 universals, so I had that done. Vibration still there. Then the left front wheel bearing became the new thing that needed replacing, so It was replaced. Vibration still there. Brought it to the Dodge dealership and they said there's nothing that we can put our finger on, But you have a recall on your injectors, so they replaced all the injectors which was cool because it was still under cummins warranty at 98000 miles, no more black smoke when I feed er the nuts! Vibration still there. So now I figured I needed some one with more knowledge in the the driveline area, so I brought it to Catco Truck Center. Well this bill hurt more than anything. It just felt like too many people had a hand on my wallet and it was really begining to Suck! They replaced the one end of the front drive shaft, of coarse the really expensive end, installed all new "U" joints in the front shaft and rebalanced it and checked the run out tolerance. The vibration still there. Well then the rear driveline was the next hot topic, so new "U" joints and cut and replace one end on the forward part of the shaft, bend or straightened the shaft to bring the runout into tolerance, check the hanger bearing. Vibration still there. Then the rear bushing in the the transfercase was the next trail and error thingy to do, so they replaced the rear bushing. Vibration still there. OH, Forgot to tell you that somewhere early on, had new tires put on because they swore up and down that it would take care of my problem, which changed nothing. Now the new recomendation is that I have my torque converter bolts checked, and if that don't take care of it that maybe you should have your front differental tore down and checked! Well the bleeding has got to stop! If you have been adding dollars to what has been replaced, you know this has not been cheap by any means, it's nuts! I mean a guy only makes so much a year! Well if you keep your hands off of my wallet and you have good advice, I'm all ears, Thanks for your time.
