Looking for some advice on a muffler. Replaced the exhaust from the turbo back and feels like I lost some power now that there is no back pressure. Running a 4" exhaust on an 06 5.9 cummins
Charged engines need the exhaust to be as free flowing as possible. No backpressure... So unless you did something different besides change the exhaust system, whatever you think you feel is only in your mind. :thumbup:Looking for some advice on a muffler. Replaced the exhaust from the turbo back and feels like I lost some power now that there is no back pressure. Running a 4" exhaust on an 06 5.9 cummins
From the turbo backThank you for the education. Last question. Will that make it feel like inlist power? I feel like when I put the exhaust on all the way back that I lost power and the pedal feels dead
What's the diameter of the stock exhaust pipe?Running a 4" exhaust on an 06 5.9 cummins
No, thats a misnomer. If anything, a more free flowing exhaust on a turbo charged engine will increase bottom end as spooling will take place sooner. Although changing the turbo can definitely alter the power curve but we're talking stock components here.You may have lost a slight amount of power on the bottom end. Free flowing exhaust can definitely do that. It should not make it feel like a dead pedal though. Maybe something else going on.
I believe the factory 3rd gen 5.9 was still 3". Although the OEM exhaust uses crimp bending which reduces the bent sections down to around 2.5" or less.What's the diameter of the stock exhaust pipe?
Thank you. :thumbup:2003 and early 2004 had a 3.5 inch and starting with the 2004.5 it was a 4 inch.
