Put the Diamond Eye 4inch turbo back exhaust on and i cant get it to seal completely where the exhaust butts up to the turbo with that clamp. Anybody have the same problem? Do i need a new clamp or is is impossible to seal 100% ?
No problems on my setup,
did the end get damaged some how?
it must be smooth and concentric to seal
Flaky rust on your turbo end will do it. If so scrape it.
Bent clamp also when you tighten it up can you move the pipe from the bottom end.
my diamond eye dp was fine when i put it on
Nothing wrong with my setup, did you connect the v-band last or before you added the rest of the system, if last that could be your problem. Try putting the downpipe on 1st then the rest
i put the downpipe on first. i will take it back off and make sure no rust flakes and maybe replace the clamp. Everything looked smooth and the clamp didnt look bent.
