Anyone with similar mods have an idea what power I have?
Next:
If I add the BD r700 upgrade turbo what power level should I be at?
Next:
Is your trans stock?BBRAM can you give me an estimate
800, I doubt it.With the 700r series bolted on, what might I expect using dual cp3's? How much power will 90 HP injectors make? I believe I have the electronic fueling tuner/programmers I need to make all kinds of fueling, but the stock cp3 is limited. I want 800 HP but don't desire to swap out my 90 HP nozzles for bigger ones. 800 HP without nitrous, that is. Possible?
it is saving for now up for a VB and TCIs your trans stock?
With that I would guess close to 500.it is saving for now up for a VB and TC
What year truck?one of my buddies put down 810 with water meth, smarty, mp-8, silver bullet, dual cp3.. whole bad valve train... and 100 hp nozzles so i really thind its possible with the right parts
If your FE is holding, as a rule of thumb you are under 550. But I am not a good one to guess the 2nd gen with nos.what kind of numbers you think i got bbram?
