Hey guys this feels like it's a never ending battle. I have been posting on this for awhile now and heres were I'm at. I bought a engine out of a 03 (manufacturing date on engine 10/20/02) that had an auto tranny. I swapped over several parts from my engine to new one except for the bell housing plate (seemed to be identical). Put engine in, everything bolted up (tranny, etc) went to put starter in and it won't go in. Is there some difference in the starter holes? They measure the same, but is the plate from the auto trannys starter hole offset alittle diffferent then the manual tranny? What a nightmare this is turning into. At this point it looks like we are going to have to pull the engine back out, seeing how luckily we didn't get everything hooked up before we noticed the starter did'nt fit, and change bell housing plates. Now, on the other hand, the engine I purchased had the apps on the side of the valve cover, and mine is under the driver battery tray. I removed the apps from the new engine and was planning on just using mine under the tray. The only issue I see here is that the wire from the apps is now just dangling there, and there is no plug from my harness to hook to it. Has anyone done this before? Should I take the harness off of my old engine and put it on the new one? I did'nt want to have to do that but I may have to unless there is another way around this. Sorry for the long post, but I am frustrated and could use all of your guys help. Thanks again
