could be your injectors, or your cp3 whining, youll get that when you raise pressure, and add fuel... does it make a popping sound under the hood when you hammer it or does it just get sluggish, what level you running the edge on, could be draining your rail and starving your injectors.... thats not good, you will loose an injector doing that, turn your edge down to level 2 or 3 and see if it makes a difference... :thumbsupi have a stock 05 with a edge with attitude installed. i recently noticed a loss in power and a noise that gets louder with acceleration. the noise sounds like a vaccum or an air leak and it increases under hard accereration. the boost and load appears to be normal on the gauges.
any suggestions???
