1 - 11 of 11 Posts
You need a new lift pump. I think that any new, non-NOS diaphragm pump is good for biodiesel, but most people go to a piston-style lift pump for better performance anyways...
There aren't many rubber fuel lines in the fuel system, I don't know if you'd need to replace all of them? Wouldn't be too hard...
What would I need to do to the fuel system on a 91 Ram 250 (Cummins) to run B100 biodiesel? I understand it is tough on rubber lines.
Thanks
Bio causes the rubber to swell, then it starts to crack and will split...Best hose to replace it - according to several sites - seems to be SAE30R9.
It's high pressure ( 150psi ) but it's a Viton fluoroelastomer hose. That will last forever.
Most sites recommend watching your fuel hoses and don't replace something that doesn't need replacing. You should get plenty of warning if you check for swelling.
The IP seals - questionable...If you've got 250K or better, you might need them anyway. Then again some last longer.
Again - don't replace just to replace. you see the leaks long before the seal or hoses go out.
And have with your bio, just made my second batch at ~ $.35/ liter. Thats less than $1.35/ gal :hyper::hyper::hyper:
So far the truck still has 1/2 tank of dinodiesel so the concentration isn't enough to notice. But I'm going to creep up to B100 about a gallon at a time keeping a close watch on seals, hoses, fuel pump, etc.
I've been checking the European sites - they've been at this 5 or 6 years...
Thanks
Thanks for helping me out. I was not sure just what would need to be changed or how it would be effected. I have seen two pretty good deals on 1st generation Dodge 250's but shied away because of using biodiesel.
I am running homemade B100 in my 97 F250 now and love it. I don't have a way yet to meter gallons into the truck, but I firmly believe I am getting better mileage out of it and I can't tell that it is different from dino diesel.
how can you not tell what your mileage is? figure out the size of the tank and how much it holds if its a stock f250 the dealer can tell you what gallon your tank/s hold and then you fill it till its full and watch your mileage
European sites
Can u please tell us what european sites for bio diesel info? Yhx
It's hard for me to determine my mileage because I have no functional odometer...
Next time you take a long drive (one sufficient to check mileage) fill up before an after then get the mileage from GoogleMapping. You can even drag your cyber path around to match any side trips you take.
1 - 11 of 11 Posts
