:welcome:
Usually when a water pump goes out it just the bearings go bad or the seal leaks or a combination of both. Some times you'll see an impeller break but then usually it will punch a hole in the housing.
What year truck is it? Is the fan clutch electric engagement of a viscus clutch?
