I moved it to the conversion forum, so hopefully some of the sites conversion gurus will see it.
I think the first decision you need to make is to select which generation of engine you want. There are technically four, but really only three to consider.
- The 2nd generation p-pumped 12 valve engine. All mechanical, often used in conversion because of the sheer simplicity and power of the engine. Many known to have rolled over 1M miles.
- The 2nd generation VP pumped 24v engine. The first electronically controlled engines. Probably the least desirable for a conversion. If you decide to tackle the electronics, may as well go with a common rail. You could p-pump a 24v and make a mechanical engine out of it. Equally reliable to the 12v.
- The 3rd generation common rail. Can pretty reliably be turned into a 600HP monster, or, you can run them factory in the low 300's. These engines will go several hundred thousand miles as well.
IMO, it boils down to whether you want to tackle the electronics. You might visit "destroked.com" and see what they have in the way of conversion kits. As the name implies, they make conversion kits to convert Powerstrokes to Cummins. If the have a common rail kit, some of the electronics may work for you..
