i was wondering if a engine adapter and flex plate from a 98- 02 cummins will work for a 47rh conversion.
1ST GEN MODERATOR
yes it will. It is the same adapter the 94 to 98 uses.
thanks philip, you rock.
i know it will, i just put a 47rh in my 02 bolted right up.
DD
Can I ask why you went with the manual controlled 47rh over the electronically controled RE.. Do you have your od and locup on switches or did you somehow splice it into the factory wiring..?
