OK, I got a question. I live in an area that requires emission testing of my truck every two years. This check also looks for equipment compliance. So if I remove any factory installed parts it will fail emission testing. How do those of you living in a testing region get around this issue. Forget the warranty issues.
Reinstall you emissions equipment every two years.
I see you're in OR, are you sure you have to test your diesel? I live in the Rogue Valley and we don't have to test our diesel pickups. You only need to test diesels if it's under a certain gvw. I would call dmv to check before going through all the hassle.
· Washington Chapter Vice President
If you have to be inspected then re-installing the Factory stuff every 2 years is the route to go.
Get to be freinds with the inspector. :rof:rof:rof:rof
