1 - 3 of 3 Posts
ok i was installing and hub bearing and rototr.....while taking the old stuff off the the shaft came out and pulled another shaft with it out of the axle what do I have to do to get those back in there.......
Diesel Junkie
Moved to the 911 section for ya.:thumbsup
Banned
Check and clean the splines on the inside end of the shaft(they'll likely have some crud on 'em). Then slide the shaft back in. Do this gently, as there is a seal inside the axle tube, and you don't want to damage it. I usually slop a little oil or grease on the splines so it'll slip through the seal a little easier without tearing it. HTH
1 - 3 of 3 Posts
