1 - 9 of 9 Posts
I put a new starter in my truck two weeks ago. When I went to start it afterwards I got a click and the horn went off and wouldn't stop until I pulled to horn fuse or relay. Got digging into it and couldn't find a cause. I even pulled to new starter, took it back and had it tested to make sure I didn't get a bad one. It was fine, put it back in and the problem was gone. Truck has started greater than ever for the last two weeks. I went out tonight to run to the store and it did the same thing again. I had just been out 20 minutes earlier with no problems...not even a slow start. When it does this it blows the 40 amp Ingnition Run fuse in the fuse box by the battery and the horn goes off continuously until I disconnect the power to it. Wires on the starter are not touching or shorting out on anything. Anybody ever had this happen or have a solution? I need my truck to get to work in the morning. HELP!
Discussion Starter · #2 ·
Anybody got anything?
Ok, I'm trying to keep this at the top of the list.
I would check the start wire on the starter and see if it is rubbed through somewhere and making contact with ground. What is your battery voltage??:confused013:
batteries and alternator working great. Everything electrical still working like normal. No warning lights or anything.
You might check the starter relay if you have not already. :thumbsup:
have tilt steering wheel?? if so wires could have rubbed through in the steering column
Checked it last time. It doesn't appear to be bad or burnt. Going to crawl underneath and trace the starter wire back to see if I see anything there. Its in conduit though so I'm not expecting to find anything.
Discussion Starter · #9 ·
Giving it up for tonight. I'm out of fuses to blow, can't find a short anywhere and my horn is keeping the neghbors up. If anybody's got anymore ideas let me know. I'll be back on tomorrow.
1 - 9 of 9 Posts
