I think they would work. i mean you can put electronic boost guages in are trucks so why couldnt you put a bully dog monitor in it and are pytometer and trans temp are already electronic so i dont see why it wouldnt work
Are you saying that the computer on our trucks already reads trans and boost temp?I think they would work. i mean you can put electronic boost guages in are trucks so why couldnt you put a bully dog monitor in it and are pytometer and trans temp are already electronic so i dont see why it wouldnt work
ok well i mixed them upa 12v does not have a cam position sensor and the 'computer' is called a PCM. a 98+ truck with an electronic engine has a ECM
I just got off the phone with bully dog and they said the outlook will only work on 98.5 and upAre you saying that the computer on our trucks already reads trans and boost temp?
What exactly would be transmitted with the obdII port other than simple things such as speed and tach, batt or would it even display them?
I have been reading alot about the watchdog and i think they only sell a probe for the egt's so i don't think there would be any way to get it to display trans temp or boost.
I am going to email bully dog tonight and get a clear answer so everyone will know.
That's not necesarily true. I hooked up a scan tool to my port and read alot of info. I was mainly focused on tranny stuff so I was reading trans temps, trans pressure, backup light operation, tcc solenoid operation, and some other stuff. I was reading it in real-time as I was driving and it showed up as a scrolling line graph and numbers underneath. I think it would only display 4 items at once but I did confirm that my gov solenoid and tcc solenoid were turning on and off erratically which is how I confirmed I had rfi from worn alternator brushes.
did you ask if they sold a sender for boost because if so they already sell the pyro and it sounds like the truck reads the trans temp so that would give you your three main gauges.I just got off the phone with bully dog and they said the outlook will only work on 98.5 and up
I didnt but from what the guy said it will only work on 98.5and up I didnt get into detail with him I just took his answer and got off the phonedid you ask if they sold a sender for boost because if so they already sell the pyro and it sounds like the truck reads the trans temp so that would give you your three main gauges.
Thats not a bad setup but for $500 i'd much rather go with traditional gauges. The bully dog is much nicer than the BD one and way cheaper that doesn't make much sense.DieselManor - BD X-Monitor how about this it comes with with probes?
Did you use OBDII scan tool or something else? I tried OBDII tool on 96' few times but all it said was "communication link error"That's not necesarily true. I hooked up a scan tool to my port and read alot of info. I was mainly focused on tranny stuff so I was reading trans temps, trans pressure, backup light operation, tcc solenoid operation, and some other stuff. I was reading it in real-time as I was driving and it showed up as a scrolling line graph and numbers underneath. I think it would only display 4 items at once but I did confirm that my gov solenoid and tcc solenoid were turning on and off erratically which is how I confirmed I had rfi from worn alternator brushes.
