Does anyone know what the problem could be?
My truck lights work fine, but I am not getting power to the passenger side blinkers for any of my 3 trailer plugs. The only fuse I could find in the owners manual for passenger side blinker is still good. Any ideas?
Check all fuses.:doh:
More info on your truck please. Year? Model / Style? etc. Generally speaking, the TPIM is the central point for sending out the current to flash the turn lights. With the year / model i can be a little more specific. If your pass turn sig's work, but just not the trailer connectors (4 and 7 way), then its possible the relay could be the culprit. Again, generally speaking, if its the TIPM, then its not a relay as we think a relay is. its actually an electronic relay (TPIM is nothing more than two ckt boards with ram and a cpu, with the boards in a T configuration). TPIM's do go bad, but i don't think its a high failure item so problem could be the connector or a pinched wire somewhere. no matter, can't give specific pin / connector number's without the year / model of the truck.
