truck is throwing a code P2509. it started a couple weeks age and the first time it started and ran for 30 and died it did that about 3 times then ran fine. that's what it does every now and then, but then some times the lift pump and the check engine light pulse and when u turn the key nothing happens the starter doesn't even turn. I replaced both batteries and took cables off and cleaned at both ends. ive checked fuses and so many other things im at a lose. any imput will be help full. the last time it did it was the 2nd until today. and it seems to only do it when its colder outside.
