Ok so I wired some HID's about 3 weeks ago using 2 30 amp relays. I did not alter the oem truck wiring in any way. I have a male connector that plugs to the oem connector. I have the low beam wire as my trigger/switch wire on the relay to close the circuit for staright power from the battery to my ballast. Everything worked great until my left Driver lamp just went out. I checked every fuse about 3 times under the hood. I was able to eliminate the circuitry of the HID and just put my oem bulb back in with no luck. I think the computer/ECM is not sending the signal to send 12V. Is there any other fuses anywhere. You guys have any ideas.
