1 - 4 of 4 Posts
Ok guys, my radio will only work right half of the time. It will only let me turn it up to a certain point, maybe a little less than half volume, then it acts as if its not getting enough power. It will shut off and then try to come back on. If im driving it will stay on a little bit better. Any clue what this can be?
When your driving or when the rpms are higher then idle? Have you had it apart and checked the wiring at all? Check and make sure its grounded, bad ground can cause alot of issues.
Ive rewired it quite a few times, just checking for that said problem, when the truck is running i have a lot les trouble with it..
Maybe the volume control potentiometer is dirty and needs some electronic cleaner.
1 - 4 of 4 Posts
