Bad idea. If you do need the flow, electrics won't do it, and keep in mind, about 20% loss going mechanical to electric, then 20% loss again going back to mechanical energy to make the air move. The load on the alternator will be stout, and it won't be able to keep up in high load situations.
Do some basic math (cfm, amperage, etc.) and you won't be so excited about those things. The asinine claims of power and fuel efficiency are based on comparing the stock fan with the thermal clutch engaged, versus the electric fan when it's not hot enough to run. This is simply dishonest.
Some folks living in mild to cold climates take their fan OFF and are fine. Diesels tend to self cool from the air charge when idling, and when under power the truck is moving, and air is flowing, so you can get away with things a gas engine cannot. The iron acts as a thermal bank (it's not very conductive, and can retain a significant amount of heat) as well.
Want fuel efficiency and power from your fan? Clean the gunk off your radiator that was put there by your puke bottle. This will keep the fan clutch from needing to engage.
