I just installed the new turbo 62/71/13 HTT turbo, now at idle the truck EGT's show 550, I barely step on the throttle and I am hitting 1200 so easy!! With stock turbo I never had these temps at idle (250-300), I really had to hit the throttle hard to get close to 1150.:thud:
I did have to rotate the outer housing so the oil drain tube would clear, i followed the indstruction to a tee though.
I marked the housing before the move, and after the move, total travel from original is less than 3/4 of inch. Would this be causing my problem?
Any one have any suggestions?
