1 - 9 of 9 Posts
Nope. Don’t waste your money on that if that’s what you’re trying to accomplish.
Reactions: GRUNT 11B
Will putting in a bigger intake horn lower EGT’s like a banks or pusher 3”
To be honest i don't think It will cause i think the stock cummins head only flows 155 cfm. I was dead set on buying a intake horn to but decided not to and saved that money for a new turbo.
It will be a waste of money. What are your EGTs hitting?
Reactions: tryNto
EGT running @normal4-500 degrees pulling a 6000lb trailer climbing a grade up to 1100 degrees
There is nothing wrong with those numbers at all. Many will tell you it’s good to get it much hotter to help clean out/burn out the cylinders and rings. These trucks stock can run a constant 1350°.
There is absolutely nothing wrong with those numbers. You're not even getting hot.
Reactions: tryNto
Those are pre turbo numbers or post?
1 - 9 of 9 Posts
