I think 400* is hot for idol I have 100hp injectors and it still idols under 300 maybe there is somthing wrong with your probe
That is in park....if i let it sit for about 3-5 min i will see the EGT drop to about 350. However, if the truck was just driving, it takes about 5-7 min to get the EGT down to 350.400f in drive or park? Thats where mine runs in drive, in park she runs about 280f.
No, the wires were never cut. But i appreciate the help.It may be a dumb question but did you shorten the egt probe wiring to the gauge? if so it would throw off the calibration. just throwing it out there.
Thanks, I will get in touch with Michael as im pretty sure its a probe/gauge problem.What isspro gauge is it? It mite need to be recalibrated I'd contact Michael @ Isspro on here since he's a sponsor.
I bought a set of used gauges and the wiring for the box was cut so it it shorter. The probe wiring itself isn't shortened... would this still throw off the calibrationIt may be a dumb question but did you shorten the egt probe wiring to the gauge? if so it would throw off the calibration. just throwing it out there.
Mr. C I have some problems. 1400 is drag race temp isn't it? Or have I been misreading posts? And the guy says 18.3 mpg, which isn't that much fuel/heat is it? Let's assume his speedo isn't way out of whack.Your temps don't seem out of line for what oyu have and the elevation. These trucks run a lot hotter than previous versions so it take some getting used to.
If you are maxed at 1400 degrees with those tires and a little extra fuel thats right inline with what the motor is designed for.
That wasn't my comment. It seems too high for a stock turbo setup, which isn't much higher than 30, and thought it should be suggested in case there is some kind of weird electrical fault going on here. But if a Smarty Jr. raises boost then forget that.cerberusiam said:The boost is about rght for the power you are running and really doesn't need to be higher.
These things don't effect the minimum temp at idle.cerberusiam said:The low rpm temp could just be the big tires and tighter converter and even then isn't that high.
A stock truck will make 1500 degrees. Add the big tires and a little more fuel and 1400 WOT is not bad at all.Mr. C I have some problems. 1400 is drag race temp isn't it? Or have I been misreading posts? And the guy says 18.3 mpg, which isn't that much fuel/heat is it? Let's assume his speedo isn't way out of whack.
Smarty remaps the boost tables and turns of the WG control on the 325 engines. I was just commenting its about right for his setup and doubtful there are any leaks.That wasn't my comment. It seems too high for a stock turbo setup, which isn't much higher than 30, and thought it should be suggested in case there is some kind of weird electrical fault going on here. But if a Smarty Jr. raises boost then forget that.
Correct, it won't effect temps at idle but it will throw more heat into things at low rpm's and take longer to cool off. I almost never see under 600 degrees once I am moving. I have a tighter TC, bigger tires, more fuel, and lots of TM removed. I assumed that was it but it looks like the default Jr settiings are close.These things don't effect the minimum temp at idle.
That explains the boost and the Smarty has already probably turned off the WG control as a guess. Crank the full power up on the POD and you should be able to make 40 psi. Maybe its just not enough rpm and fuel to drive the boost all the way.I have a Quad Boost fooler on the truck but sadly on or off the boost is the same and I will not clamp the wastegate as i dont want to shell the turbo on an accidental skinny pedal back out at max boost.
The wonderful tech support at isspro is sending me a new amp box and until that arrives i just wanted to be sure that nothing else could be the culprit of this seemingly high egt problem.
Correct me if im wrong but a lower stall on the TC (which i have) will allow for more power to be applied at lower RPM. If i am correct, that means the tranny will be applying power at ilde (which is why my truck will take off just by releasing the brake). So, if in drive at idle withe the brake applied, i expect the EGTs to be a bit higher but just dont know if the numbers i am seeing are normal. It seems like they might be but the new amp will tell the tale.These things don't effect the minimum temp at idle.
Mine did when I upgraded the TC. They go higher faster in gear than they did with a stock TC.i expect the EGTs to be a bit higher but just dont know if the numbers i am seeing are normal.
3.73 gears with the 37" tires (forgive my mental math) makes about 3.24 gearsWhat gears are in this truck?
