I just got my EDGE W/ATT in yesterday. Has anyone had any problems drilling and tapping the manifold? Or, is there another place to install? Thanks!
Super Mod
I had no problems when I did mine. I started with a small hole and moved up in size to reduce the shavings size. I had someone keep a magnet on the bit and hole while I was drilling to reduce the amount of shavings that fell into the manifold.
or take the inner liner out of the fender. You should have a better access there.
Thanks!
I have a right angle and the finger to pull the trigger. Thanks to all the help. Gonna have the new turbo installed on Friday, install everything the S&B intake and Edge on SAT. or SUN. and the DPF delete on Monday. After I install it, I have about a 200 mile drive to make. SHould be interesting to see the difference. I will keep you posted! :hyper:
Sounds like a fun weekend:woot:
