1 - 11 of 11 Posts
Heck if I know
I am sure everyone but me knew this but. If your installing an EGT probe do it with your truck running. Then the exhaust will blow the metal flakes out of the exhaust. Rather then running the risk of some falling into the exhaust and chewing up the turbo.
egt probe
I just bought a egt gauge but not sure where to drill for the prob.I have 06 5.9.Thanks,Vann:banghead:
On call 24/7
Heck if I know
On call 24/7
Also to Vann, dont run the tap all the way down or the probe will be loose.
Gentlemen,thanks.I would have thought the ex would have just blown the shavings on through,never thought about shavings hurting anything.The directions that came with the gauge don't tell you crap.Have you guys installed a tran temp and oil temp gauge.Thanks for the help! Vann:thumbsup:
On call 24/7
I've never done an oil temp but have a tranny temp gauge. Did you get a moniter, attitude or commander?
On call 24/7
You can get the fitting you need to install it in the hotline, which is supposed to be the most accurate. I just put mine in the test port on the passenger side of the tranny for now.
Take a look at the link and go to page 27. Also if you dont want to tap the EGT while the engine is going. put lots of grease on the drill bit and drill really slow take your time.
http://www.edgeproducts.com/product_images/product_variation-user_manual-228.pdf
:ditto: this is how i have installed all my pyros and no problem so far. Just drill slowly and with lots of grease. Wipe the grease off the bit and manifold regularly. you cant be to careful.:thumbsup:
1 - 11 of 11 Posts
