Once the DPF and rear CAT are removed, where are you guys installing your EGT probes? I want one pre-turbo and one post-turbo. I am using a PMT and Gen 1 BADP. Thanks.
I have it set up so one is in the EGR block off plate pre turbo and then I have one at the lower 45 degree bend post turbo. I had to have a bung welded on mine since i used a 5" TBE from Magnaflow that is for a 5.9L.
CF Administration
mine is right above the turbo flange on the manifold and in the cast iron elbow piece on turbo so its drilled and tapped not anything welded to the down pipe like some do
Thanks, all
