Hmmm, typically the probes will tend to get whacky after a few years and require replacement.
Not sure on what the specs should be for testing the probe, but if you throw a multimeter on it and test resistance you should find the resistance vary if you heat up the tip with a lighter. If their is no resistance between the 2 probe wires (open circuit) or the resistance doesnt vary if you heat the tip, the probe is your issue.
