1 - 9 of 9 Posts
Hi all,
So lately here in NE Oklahoma its been in the teens to 20's at night. I generally let my truck idle for about 2 minutes before taking off. I have noticed a big puff of white smoke when I take off initially. When I let it sit to idle, I put it in high idle, 1100 rpm. I noticed the other day when I climbed in the truck my egt was only at 254 degrees. Shouldn't that be a little higher than that? I'm guessing because of that the cylinders are getting loaded up with diesel thus the white smoke. Anyone know why this is happening?
I just replaced all 6 injectors about 1,500 miles ago with new Bosch motorsports. Thanks in advance for the insight.
Well it could be condensation. . Take a whif of it next time. Mine does this when it's under 20 out. But I know on mine it's not unburned fuel.
White smoke is heavy and kind of lingers.
Condensation drifts away and evaporates quickly.
Seems like I lingers a bit. I have checked all the usual stuff and nothing abnormal, however the low egt is really what's got me wondering. I had found in another thread that 350ish was the norm at idle. 254 does seem pretty low.
Thanks for the info, it was kinda buggin me.
What were your coolant temps at? I know when I first fire my 6.7 up and it's cold it'll barely get over 200 until I either idle it up or engage the exhaust brake... And even if I idle it up it doesn't go up very much... I never had an EGT gauge on my 06... But I know it'd puff white and n start up even when warm.. And when cold it'd be a little bigger and cycling of the grid heater till she warmed up a bit...
That sounds exactly what mine does. I guess I was just getting paranoid, thanks guys for the responses.
Discussion Starter · #9 ·
And my coolant temps were generally 10-15 degrees above the outside temperature.
1 - 9 of 9 Posts
