1 - 10 of 10 Posts
I bought my truck from my mother in law after her husband passed away. It's a 2010 2500 Cummins that has a DPF delete, full exhaust, intake, and I know it has been programmed with a tune on it, I believe it is 70 hp but can't remember what he told me for sure. I see the EGR has been unplugged and I am wondering if I can do an EGR delete on it without a tuner or reprogramming it again? Does anyone have any idea on this?
Yup
Yep you can remove without retune. The fact it is unplugged tells you that.
Sent from my SM-T350 using Tapatalk
Reactions: RamHunter18
Remove away. You'll be fine
Remove a big heat sink of the top of the exhaust manifold and less cooling system fittings to fail. Looks better.
Remove it. Why pack it full of soot and make it harder to get working again if you ever need to. The only reason i can see to leave it is to maybe slide on a road side visual if a cop ever looks.
Discussion Starter #9
I was hoping that was the answer but wanted to double check. Are there any down sides to taking the EGR off? Other than emission laws. I just don't like the idea of all the soot in my motor even though the valve is unplugged I'm sure some gets pas the butterfly.
Nope. I was gonna leave mine installed but with the way of this f ed up world now I said screw it and removed all of the crap. I have a bed full of junk now and a much smooth running truck. I had forgot how well the raceme tune abd trans tune run
1 - 10 of 10 Posts
