1 - 4 of 4 Posts
ok first off 2009 3500 CC 6.7 just so I don't forget
the egr kit pics were ok but dark and several pieces didn't get used???
there were 3 block off plates but I only found use for 2?
---egr cooler rear on manifold and dual piece on air intake
---whats the 3rd one for? oh I didn't remove the cooler mount
second was a pic & reference to unplug an EGR airflow valve?
---looked like it was in the air intake pipe but
---the only thing I see looks like a MAF to me
3rd I solved myself was the coolant plugs, LOL the one that is for the solid pipe that says vent when filling was way to big for metal pipe or the hose so I ran the 2 together like its just a bypass with the egr cooler gone.
Who makes the kit?
You can go on the manufacturers website and view the delete instructions there. Adjusting the screen brightness should help you see what to do.
It sounds like you've deleted the egr valve so the only other "air valve" is the throttle butterfly valve on the intake.
Usually the tuner dictates what equipment gets unplugged, not the egr delete kit?
Who makes the kit?
its H&S maybe just a generic kit with all parts, that's not a bad idea I need to figure out this airflow their talking about
1 - 4 of 4 Posts
