I have an 07 5.9L with EFI Live from anarchy diesel with a CSP5 switch and having a huge problem. So today when I get out of the gym today I wait to start the rig the ABS light check engine light and parking brake light are all on. Odd, it starts up fine lights stay on and tach drops to 0 but keeps idling then the tach proceeds to bounce between 0 and 750 rpm and the trans light is coming on and off the truck is chiming like crazy and check gauges light is coming on and off. Drove home (less than a mile away) Trans was at 125 degrees so it's not hot and shifted fine. Could it be the CSP5 got unplugged? When I try to clear present dtc codes it says there aren't any do I just hit clear all codes. A buddy with an SCT tuner with a ford which I think is similar to EFI told me to turn the knob down to level 1 (stock) and unplug the battery terminals for about an hour to reset computer. Will I lose the tunes if I do that? 3borce have you heard of this problem and what actions should I take? The manual mentions nothing about a truck freaking out. Also when I stopped at a stop sign the truck shut off in drive if that is relevant. Truck doesn't need to be driven tomorrow so I have all day to fiddle with it. Please help me yall thanks
