1 - 3 of 3 Posts
does anyone have a 2000 dodge diesel like mine that is running the edge comp box with a smarty on revo tune if so what is the best tune for it because my truck for some reason does not like the revo tunes and is throwing codes about fueling calibration and stuff
I think that the comp does timing as well as fueling? I think the smarty does timing as well. If this is the case I would disconnect the comp from the map sensor and run the smarty on the revo tune. As I said I am not 100% sure on this, but you could try it and see if it works out.
I have a 98 and run the comp and this smarty revo. you're going to want to run the smarty on catcher only tunes with no timing added. let the comp box take care of the timing. If u are getting a P 0602 code then that is normal for non stock software
1 - 3 of 3 Posts
