He is right. I dont have the timing option on mine.Comp doesn't have the timming option:lol3: I do!
Never played with it. Cant afford the fuel:rof, If I get a chance I'll let you know, mine's curently set to stock due to the SC stack.
You're not going to hurt anything with it on the stock setting. That setting is mainly intended for those that are stacking with another tuner that adds its own timing.I have been playing around with the timing options on the edge. It maybe me but it seems that the truck is more responsive when the timing is set to stock and the power levels are higher than the mileage setting. Any idea if doing this is good or bad? Cowboy you seem to be on the front of these 6.7's.
With the MP-8, leave it on the Juice timing:thumbsupi have the timing option and my mp8 should be here friday should i set the timming to stock on the edge or just leave it at juice will it be fine with the stack thanks guys
The timing option is on the Same menu as the Low-end Responsiveness and other Settings.:thumbsupso how do you know if your edge has the timing option?
