i feel like i am beating a dead horse with this question :thud:
ok after looking around and asking on what to stack with his Edge Juice with Attitude, my buddy is going to stack the smarty but i have a few questions.
what does each one do?
edge does timing and duration?
smarty does timing and fueling?
i know the smarty can load catcher with no timing but what does catcher actually do and can he turn his edge to 0 and just run the smarty with timing?
he is running a 2002 dodge
Cummins Enthusiast
The Juice does timing, fueling, and duration.
The Smarty does the same thing basically...
He can stack them together just fine, just use the even numbers on the smarty only, which doesn't add any timing, since you can't limit timing with the Juice.
If he would like to use the odd number settings on the Smarty that use timing, yes he can simply put his Juice on level 0 "stock" and use the Smarty only.
if i would put my smarty on fuel milage and edge juice on 0? can i do that?i had my edge on 1 and smarty on 8 and i got 11mpg. than i ran my edge on 5 and smarty on 8 and i got 16-17.
