1 - 9 of 9 Posts
May have found out my intermittent no start. Weird miss at idle. Is there anyway to replace that wire on the pump. I'd hate to replace my VP all for that Dahm wire
so the pump wire is bad? not sure what wire you are referring too. the wire you tap for more power?
I mean you can solder in a new wire fine, but I am not sure I think that will fix any issues unless the wire is shorting out.
The wire you tap the pump where it connects is corroded. Idk if this is part of my weird electrical no start problem but I'm sure it's not helping
SCOTCHLOKS TO THE UNRESCUE !!!!!!!!!!!!
Ed
If the wire is corroded where the pump tap is try using contact cleaner and solder a new tap wire on and use so liquid tape to seal it
Mopar1973Man.Com
Reactions: pmccue
Canadian Diesel Junkie
Lol @ Ed!!
1 - 9 of 9 Posts
