1 - 19 of 19 Posts
I was wondering if anyone has stacked anything with an attitude on a 2000. I was thinking maybe smarty but if there is a better stack i would rather get it.:thumbsup
that is a very good stack:thumbsup
Would that be a better stack than an edge ez?
You can't stack an Edge Attitude with an Edge EZ. The Smarty is a good choice, just don't add to much timing.
thanks for the help.
if ya do get the smarty you should post results....someday i might get one:thumbsup
How much more power do you get when stacking the 2? And does it work with the Hot unlock?
Discussion Starter #9
thanks for the advice guys. i think i will need an exhaust before i get it though....i will let you know gus! i would like to know how much more power you get also if anyone knows!
Bump..... Thinkin about the same stack
I always heard you lose hp on top end,but you got a bunch on bottom end.Smokeyburnouts said his truck dont run good with the hot unlock and the smarty,but does good without the hot unlock
You can always just buy the adrenaline,the dyno tune blows my smarty/comp stack away
Do you have the adrenaline stacked?
post some results when you get this done im thinking of geting a smarty also..
im interested in stacking something with my juice also
I would put some sticks in the truck before you get the smarty....:thumbsup
just my thought...I like having the sticks so you know you have "good" power all the time and them you tweak/add some more just by hittin the up arrow on hte juice....the hot unlock adds some good fuel too....:thumbsup
Might wanna add some nuts to the tranny first....???
Discussion Starter #17
yeah i have been wanting to get the hott but i didn't know if it was worth it. i need a new fuel pump too but it's kinda expensive!!
the stack does not work on the does not work with the hot juice. i think its because it adds too much duration. you have to run the Smarty turned all the way up with no timing and then run the Juice on level 5 for best results
when I ran the smarty on #2 and the Juice on #5 it was a good feel, i personally think the catcher setting make it too jumpy...kinda
1 - 19 of 19 Posts
