1 - 13 of 13 Posts
Has or does anybody have the Edge juice and quadzilla stacked? If you do let me know how you like it or dislike it. I was thinking about stacking them. Thanks in advance guys.
Ray :thumbsup
which quadzilla?
the Xzillarader, sorry
bump...............
Tech Specialist
If it does timing then you can't stack it with a juice cause the juice already does timing.
Xzilliraider is fuel only box, but also needs to tap pump wire. Don't think you can tap pump twice.
Discussion Starter · #9 ·
On XDP.com it says that you do not have to tap the pump wire. Reason why I am asking is because I was looking at the stack chart that one fella put up on here and it said that I could stack the two. Trying to see if it would even be worth it or not.
Thanks guy
Ray:thumbsup
no it doent stack so you should sell it to me really cheap because its no use to you :D i need something to stack with my ez but seriously i have no idea... haha but if you want to sell the xzileraider pm me
Discussion Starter · #11 ·
i dont have it yet, im trying to get some opinions about it before i decide to spend the money on it.
The Xzilliraider must tap the pump wire or it will not work, it is fuel only.
Discussion Starter · #13 ·
I dont know man, but the site says specifically not to tap the pump wire. Maybe im miss reading it or mis inturpiting it.
1 - 13 of 13 Posts
