It is an old school programmer, but will get you gauges, (boost, EGT, Trans and others) and an extra 80HP
Original Edge Products Juice with Attitude for 2007.5-2009 Dodge Ram 2500/3500 - 6.7L Cummins Diesel
5 On the fly adjustable power levels
Power Level 1 25 HP and 70 lb-ft
Power Level 2 40 HP and 90 lb-ft
Power Level 3 50 HP and 120 lb-ft
Power Level 4 65 HP and 160 lb-ft
Power Level 5 80 HP and 200 lb-ft
Performance tuning for mileage, towing, daily driving, and performance
Dynamic safety features (cold engine protection, backdowns, turbo timer)
Improves low-end response
Adjustability has never been easier or looked better. The Attitude in-cab controller combines sleek new engineering with cutting edge technology to provide state-of-the-art performance in adjusting levels and reading EGT and boost. With the addition of the controller to your Juice module, there is no longer a need for gauges. The backlit LCD display screen allows a clear reading of EGT temperatures, boost readings as well as a host of other parameters. With the push of a button, you can switch power levels and have adjustability on the fly.
