EDGE install help
479 Views 5 Replies 3 Participants Last post by  atc250r18
Where does this plug go??
directions say the map sensor by the fuel rear connector HOWEVER that plug shown in yellow is only a 3 wire plug...
help..............
nevermind, found it... directions would have been easier if it said back side of air horn... heh...
Installed mine last Sunday and the connector for the turbo timer does not match any of the connectors under the steering column. Already called edge and they're sending me another cable with the correct connectors. That ate most of my time searching for the connector that's not even there. hopefully you won't run into that issue.
That's what I thought at first too but I ended up taking the columb cover off and it was there. It's a rectangular plug with 4 or 5 wires right?
Yeah! removed the plastic & metal column too and only saw 2 connectors (i think 1 with 5 pins connector but only use 4 wires and the other one above was a rounded black connector). still waiting for the replacement in the mail:)
:thumbsup Cool!
