1 - 11 of 11 Posts
I'm looking at buying edge insight cts found a new one on amazon same stock number 83830 for 332.00( comments please ) ......I have a 08 3500 deleted dpf an smarty jr set on stock I tow a good bit with horses cows equipment but don't hot rod with my truck ....I've read I need to buy an install a egt probe but is that important/ vital since I don't hot rod ( I will do just may be a few weeks down the road).....is this product a plug in an ready to go setup if you wait on the egt probe..thanks
Mount it, plug it in, choose what you want to watch and you're good to go.
I love mine and yes you should get the egt probe. Just plan on it fairly soon.
· Diesel Filled Veins!
EGT probe is for sure nice to have. If you have the EGR deleted already you can very easily drill and tap the rear block off plate. If you don't have the EGR deleted then you'll have to drill and tap the exhaust manifold. It's nice to have just to see how hot your truck is running, also you can use it to control your right foot for fuel mileage if you want - lower EGTs = less wasted energy but your boost pressure on the Insight can help you with that as well. Even towing you can run your EGTs high so it is nice to monitor :thumbsup:
And yes, that's a good price. That's what I got mine for including a rebate.
I would call Edge and verify ther're an authorized dealer. If not then there's no warranty.
Thanks y'all I'm doin some calling to day so may have more questions
hey i am thinking about getting one from the same place. so please post on here when you find out if they have a waqrrenty please. thanks Mopar71
I don't remember seeing it as a data point on my 07.5. There are different data points for different years so post what year you have and someone who has the same year can check theirs and see if it's listed.
1 - 11 of 11 Posts
