1 - 10 of 10 Posts
Ever since I installed the Edge, my truck has alot more knock. I keep it on level 1, but even on stock setting, it has a loud knocking.
Is this knock normal for the Edge?
what year, and its probably timing noise when timing advanced it gets little louder i wouldn't think you would hear it much on setting 1, does it get more noticable each level
seems the same on each level. Diesel Kleen seems to help a little.
Like Meyer said, its a knock from the timing advance as well as you are hearing the injector noises. The edge also changes the Injection Pulses if i remember right.
Would the Air Dog help the fuel knock?
I thought I heard knock also, until i looked and seen my rubber grommet that all the cables went through was ripped. That is where all my noise was coming from.
Discussion Starter · #9 ·
same here but it's alot louder on the outside. I thought the Air Dog quiets the fuel knock in the MP-8 and EGR delete?
It seems to help get the Fuel Pressure up top resolve the EGR issue but the knock you hear is a little different. It is what Meyer said.
1 - 10 of 10 Posts
