1 - 3 of 3 Posts
ok i searched how to make a smoke switch watched the video on you tube and it still doesnt work. i have the switch wired into the A and the C wire on the plug of the edge that goes into the sensor as the video shows. i used the same conectors in the video, what did i do wrong i barely get any smoke. can you make a smoke switch for an edge comp or just the juice with att.
did you install a resistor i believe i used a 10ohm on mine
the switch has on in it do you think i just didnt tap the pump well i know its the small black wire closest to to block i used a quick tap. should i strip it some and solder it?
1 - 3 of 3 Posts
