The Edge CTS will monitor the following through the OBD port:
Accel Pedal Position
Barometric Pressure
Battery Voltage
Boost
Calculated Load
Corrected Speed
Engine Coolant Temp
Engine Speed
Fuel Level
Fuel Rail Pressure
Gear
Gear with Reverse
Intake Air Temp
Manifold Air Pressure
Mileage Coach
MPG Instant
MPG Average
Output Shaft Speed
Throttle Position
Time 0-60
Time 1/4 mile
Trans Temp
Vehicle Speed
By adding the pyro probe, the CTS will also monitor EGTs. It looks like I will still need a mechanical gauge to monitor the fuel pressure. Are there any other important gauges that I would want to add that the CTS can’t monitor? Besides adding the pyro probe and fuel pressure gauge, it looks like the CTS has most everything covered??????
Missing EGTs
Ops, Didnt see the bottom
World Champs!!!
You can get the expandable sensors for the CTS, so you can have fuel pressure feeding the CP3 on that, maybe oil pressure with that also, and boost if you go over the factory sensor limit of 44ish. Everything else is on there and accurate via my testing/comparing
Piggy Piggy
:agree2::agree2:
One part at a time
It seems a lot cheaper at first but it still comes out pretty expensive if you add a few of the expansions. I love mine though, set the alarm for each gauge and not have to worry about hawk eying the gauges all the time.
