I just scored an edge drag comp for a smoking deal locally. It's for an 02, so I don't need the adapters, sweet!
Few questions
- tapping the pump. I just replaced my pump and I want to "try" and keep a warranty on it. But at the same time I want a solid connection for the best performance. Wire taps are out, I hate them. I'm down to the Stealth plate or cutting/soldering the connection. Is the steath plate a good connection for this setup? Is it work the $50?
- Boost elbow - The reason I got a smoking deal is the guy didn't have the boost elbow, can I put any boost elbow on there, or should I get the one from edge?
- Can I run this for a couple of weeks without EGT/Trans/Boost gauges? Or should I just hold off on installing it until I get my gauges in. I already have fuel pressure installed, a rebuild vp44 and an airdog.
Thanks guys!
Few questions
Thanks guys!
