yes.
I def felt a difference.
I only spent 50 to get it unlocked so i feel it was worth it,
Is It Worth It To Get The Comp Box Hot Unlocked
Ditto on both!!Yes...and since it runs so much stronger it'll destroy your EGTS. :S: :hehe:
Quick fix would be to turn it down to 5X4 if EGTs are an issue.
I'm with dieselsoon on this one. If you're getting bigger injectors (150's) then you won't be able to use it without cooking your motor. Would 100's and getting hot unlock be a quicker setup than getting 150's and having to leave the juice on 4 when drag racing (to keep egts OK)? :doh:you get upgraded injectors the hot unlock is pointless because of high egts so um not spending the 100bucks to get it
You can see in my sig what I got and this past summer I also added a Snow Performance Stage 3 water/meth system. I went sled pulling with it on 5x5 and the water/meth kicking in low and hard and my egt's were at 1200 and the boost was 47psi. However, running empty with it on 5x5 and the w/m kicking in low I can still see high egt's. I need twins!!!
